Ducellier igition components
PostPosted: Sat Mar 28, 2009 7:57 am    Post subject: Ducellier igition components Reply with quote
Will these bits fit a 1750 Equipe? I have no idea about these Ducellier distributors, so I hope that one set of components fit all serial numbers!
http://cgi.ebay.co.uk/MINI-ALLEGRO-METRO-MAXI-DUCELLIER-IGNITION-SET_W0QQitemZ380113617922QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item380113617922&_trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A10|39%3A1|240%3A1318
Having some problems with the link! Item no. 380113617922
Hell has frozen over...... the car formally known as 'Heap' is back on the road!
LankyTim
PostPosted: Sat Mar 28, 2009 10:51 am    Post subject: Reply with quote
Your dizzy looks a bit corroded, would it not be better to sling a complete working unit on? Wouldn matter if it was Lucas or Ducellier that way.
I must have that dig around, im sure ive got some spares that I can throw your way!
1979 Allegro 1500 S2 special 4 door saloon
Previous allegros,
1977 Allegro 1300 super 2 door. SCRAPPED
1978 Allegro 1300 super 2 door. SCRAPPED
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Sat Mar 28, 2009 6:07 pm    Post subject: Reply with quote
Hmmm - I didn't look closely, but yes, it didn't appear to be pristine! Hopefully it'll just clean up.
It might be simpler if I swapped the dizzy for a Lucas one, as parts seem to be easier to find. BUT my bidding finger has been too eager and has jumper at these bits on Fleabay - If I don't win then I'll take up your offer.
Either way, I'll be fitting new points, cap, rotor and condenser to the car. I really hope the engine hasn't seized as I want to hear it run at Easter!
LankyTim
PostPosted: Sun Mar 29, 2009 10:45 am    Post subject: Reply with quote
Id start by taking the spark plugs out and sticking a little diesel down each bore, help it unstick a bit.....
I bought a complete maxi engine and box from ebay however, £50. Bargain! Runs a treat too.
Previous allegros,
PostPosted: Sun Mar 29, 2009 6:15 pm    Post subject: Reply with quote
Yes, I'll need to look into exactly what to do to avoid killing it if it has seized.
And I have now found Ducellier service items, they do appear to be readily available.
PostPosted: Tue Mar 31, 2009 6:36 pm    Post subject: Reply with quote
Ducellier distributor components are readily availible from minispares.com but only parts like cap, arm, points & condensor, cheers, Laurence.
Mike Dean
PostPosted: Wed Apr 01, 2009 9:28 pm    Post subject: Reply with quote
If you're considering replacing it with a Lucas unit, the document I pointed out a good while ago could be useful references:-
Quote:
I just came across this: Marcel Chichak's technical documents - www.starchak.ca/tech/tech.htm
The documents that particularly caught my eye were:
Tuning the Lucas distributor - lucastuning.pdf
and
Lucas distributor database - lucas.pdf
Mike.
