LankyTim
Joined: 29 Apr 2008 Posts: 474 Location: Stoke on Trent
Posted: Sat Mar 28, 2009 10:51 am Post subject: |
Your dizzy looks a bit corroded, would it not be better to sling a complete working unit on? Wouldn matter if it was Lucas or Ducellier that way.
I must have that dig around, im sure ive got some spares that I can throw your way! _________________ 1979 Allegro 1500 S2 special 4 door saloon
Previous allegros,
1977 Allegro 1300 super 2 door. SCRAPPED
1978 Allegro 1300 super 2 door. SCRAPPED
Posted: Sat Mar 28, 2009 6:07 pm Post subject: |
Hmmm - I didn't look closely, but yes, it didn't appear to be pristine! Hopefully it'll just clean up.
It might be simpler if I swapped the dizzy for a Lucas one, as parts seem to be easier to find. BUT my bidding finger has been too eager and has jumper at these bits on Fleabay - If I don't win then I'll take up your offer.
Either way, I'll be fitting new points, cap, rotor and condenser to the car. I really hope the engine hasn't seized as I want to hear it run at Easter! _________________ Hell has frozen over...... the car formally known as 'Heap' is back on the road! |
LankyTim
Posted: Sun Mar 29, 2009 10:45 am Post subject: |
Id start by taking the spark plugs out and sticking a little diesel down each bore, help it unstick a bit.....
I bought a complete maxi engine and box from ebay however, £50. Bargain! Runs a treat too. _________________ 1979 Allegro 1500 S2 special 4 door saloon
Previous allegros,
Posted: Sun Mar 29, 2009 6:15 pm Post subject: |
Yes, I'll need to look into exactly what to do to avoid killing it if it has seized.
And I have now found Ducellier service items, they do appear to be readily available. _________________ Hell has frozen over...... the car formally known as 'Heap' is back on the road! |
Posted: Tue Mar 31, 2009 6:36 pm Post subject: |
| Ducellier distributor components are readily availible from minispares.com but only parts like cap, arm, points & condensor, cheers, Laurence. |
Mike Dean
Joined: 01 May 2007 Posts: 455 Location: North London
Posted: Wed Apr 01, 2009 9:28 pm Post subject: |
If you're considering replacing it with a Lucas unit, the document I pointed out a good while ago could be useful references:-
Mike. |
