Engine
Post new topic   Reply to topic    Allegro Club International Forum Index -> Wanted
Jim Lavery
PostPosted: Sun Apr 20, 2014 10:46 pm    Post subject: Engine Reply with quote
I'm looking for a complete 1500 engine for my estate.
Jim
PostPosted: Mon Apr 21, 2014 8:22 pm    Post subject: Reply with quote
Jim,
You will also need clutch hydraulics, driveshafts, gearchange rods, engine mounting brackets, exhaust front pipe, radiator and a few hoses.
All of these are different between A-series and E-series power units.
Best bet would be to buy a donor car if you can find one. Do you want the single carburettor version or twin?
Jim Lavery
PostPosted: Mon Apr 21, 2014 10:38 pm    Post subject: Engine change Reply with quote
Hi Paul,
Thanks for the advice. Looking at what would need to be done I think i'll keep the car as a 1300 and try and improve it.
Thanks again.
Jim
PostPosted: Tue Apr 22, 2014 7:45 pm    Post subject: Reply with quote
Jim,
If you can find a late Allegro series 3 'A+' 1.3 engine, that will give you an extra 9bhp (as long as you use the corresponding carburettor and exhaust downpipes) and higher overall gearing for economy and cruising refinement.
At one time, the cost-effective way to improve a 1.3 Allegro was to fit an MG Metro power unit, but unfortunately demand from the Mini community has pushed prices quite high.
Otherwise, as I am sure you probably already know, there is plenty of choice out there for A-series tuning parts and plenty of information either from the internet or a decent book such as Vizard.
Please keep us updated on what you decide to do Very Happy
Jim Lavery
PostPosted: Tue Apr 22, 2014 11:10 pm    Post subject: Engine change Reply with quote
Hi again Paul,
My car is fitted with an early series 3 A+ engine that was fitted by a club member who previously owned the car.
I have written an article for the Quatric magazine that will explain a lot of the work done on the car I hope you enjoy it.
Thanks again.
Jim
Jim Lavery
PostPosted: Sat Apr 26, 2014 11:13 pm    Post subject: Advice Reply with quote
Just a question about a recurring problem. It's something I've asked about before. When I start the car up first thing if I blip the throttle I get quite a bit of blue smoke. If I don't touch the throttle and just let the car run for a few seconds there is no smoke. It can't be the cylinder head as it has new valves, seals, and guides. I've also done a compression test and all the cylinders seem to be OK.
My question is, could it be the crank case breathers putting oil into the carb then it burning up. Can these be cleaned. As far as I can tell to clean one would be easy but another is attached to the timing chain cover. I have also read in the manual that the oil filler cap is a replacement service item. Can you still get these?
Jim
Peter S
PostPosted: Sun Apr 27, 2014 7:28 am    Post subject: Reply with quote
Hi Jim
Oil filler caps are still widely available from ebay or Mini specialists. For example, Mini Spares list part GFE6003 (genuine) or GFE6003MS (non-genuine).
Post new topic   Reply to topic    Allegro Club International Forum Index -> Wanted All times are GMT
