		| Author | Message |
		| Jim Lavery
				|  Posted: Sun Apr 20, 2014 10:46 pm    Post subject: Engine |   |
				| I'm looking for a complete 1500 engine for my estate. _________________
 Jim
		| Back to top |  |
		| Paul-V
				|  Posted: Mon Apr 21, 2014 8:22 pm    Post subject: |   |
				| Jim,
 You will also need clutch hydraulics, driveshafts, gearchange rods, engine mounting brackets, exhaust front pipe, radiator and a few hoses.
 All of these are different between A-series and E-series power units.
 Best bet would be to buy a donor car if you can find one. Do you want the single carburettor version or twin?
		| Back to top |  |
		| Jim Lavery
				|  Posted: Mon Apr 21, 2014 10:38 pm    Post subject: Engine change |   |
				| Hi Paul, Thanks for the advice. Looking at what would need to be done I think i'll keep the car as a 1300 and try and improve it.
 Thanks again.
 Jim
		| Back to top |  |
		| Paul-V
				|  Posted: Tue Apr 22, 2014 7:45 pm    Post subject: |   |
				| Jim,
 If you can find a late Allegro series 3 'A+' 1.3 engine, that will give you an extra 9bhp (as long as you use the corresponding carburettor and exhaust downpipes) and higher overall gearing for economy and cruising refinement.
 At one time, the cost-effective way to improve a 1.3 Allegro was to fit an MG Metro power unit, but unfortunately demand from the Mini community has pushed prices quite high.
 Otherwise, as I am sure you probably already know, there is plenty of choice out there for A-series tuning parts and plenty of information either from the internet or a decent book such as Vizard.
 Please keep us updated on what you decide to do
		| Back to top |  |
		| Jim Lavery
				|  Posted: Tue Apr 22, 2014 11:10 pm    Post subject: Engine change |   |
				| Hi again Paul, My car is fitted with an early series 3 A+ engine that was fitted by a club member who previously owned the car.
 I have written an article for the Quatric magazine that will explain a lot of the work done on the car I hope you enjoy it.
 Thanks again.
 Jim
		| Back to top |  |
		| Jim Lavery
				|  Posted: Sat Apr 26, 2014 11:13 pm    Post subject: Advice |   |
				| Just a question about a recurring problem. It's something I've asked about before. When I start the car up first thing if I blip the throttle I get quite a bit of blue smoke. If I don't touch the throttle and just let the car run for a few seconds there is no smoke. It can't be the cylinder head as it has new valves, seals, and guides. I've also done a compression test and all the cylinders seem to be OK. My question is, could it be the crank case breathers putting oil into the carb then it burning up. Can these be cleaned. As far as I can tell to clean one would be easy but another is attached to the timing chain cover. I have also read in the manual that the oil filler cap is a replacement service item. Can you still get these?
 Jim
		| Back to top |  |
		| Peter S
				|  Posted: Sun Apr 27, 2014 7:28 am    Post subject: |   |
				| Hi Jim
 Oil filler caps are still widely available from ebay or Mini specialists.  For example, Mini Spares list part GFE6003 (genuine) or GFE6003MS (non-genuine).
		| Back to top |  |
