Buzzing electronic hazard flasher unit
PostPosted: Wed Jun 16, 2010 10:15 pm    Post subject: Buzzing electronic hazard flasher unit Reply with quote
When I switch on the hazards, the electronic flasher unit just buzzes, nothing else happens. I tried another one, and that does the same (I believe they were both working fine before).
What could cause this? I'm confused, as I doubt it is the unit itself.
PostPosted: Fri Jun 18, 2010 4:21 pm    Post subject: Reply with quote
Colin,
It is likely to be the hazard switch shorting out. It won't blow a fuse because the circuit will switch rapidly limiting the current draw. (Hence the buzz). Try disconnecting the earth wire at the switch (Black if my memory is correct) and see what happens.
PostPosted: Sat Jun 19, 2010 10:36 pm    Post subject: Reply with quote
Well, it magically fixed itself before I disconnected the wire! I just tried it first and the hazards were working fine. I wish all my car's problems would fix themselves!
I had unscrewed and lifted forward the heater cover the other day, and after putting it back is when I discovered the buzzing. I had to unscrew, lift forward and then refit the heater cover again a day or so again, and now the hazards have fixed themselves. I didn't do anything to the switch or wiring, maybe it was something I did without knowing that broke and then fixed them?? Very odd!
