Hazard warning lights not working (resolved)
PostPosted: Fri Jan 09, 2009 8:05 pm    Post subject: Hazard warning lights not working (resolved) Reply with quote
I'm posting this as it may be of help to somebody, someday!
When I reassembled my car during it's restoration, I found that the direction indicators worked perfectly fine, but that the hazards didn't. There was an intermittent quiet 'tick', not was loud as it should have been, and it was totally unpredictable. This situation did override the direction indicators when the indicator switch was up or down and the hazards switch subsequently pressed.
I tried swapping the flasher unit (it was the correct type) for a known working one, and then swapping the switch (for a known working one). Neither made any difference.
At some point, the fuse was removed, and I think replaced with an another (not sure which ratings either were), which made the 'ticking' sound perfectly correct, but still the lights didn't work.
Eventually (and partly for another reason) I removed all the fuses, without noting what ratings had been in place, and replaced them using the correct ratings for the S3 wiring loom given in the owner's handbook.
This totally fixed the problem.
No other items were working incorrectly before, and I do not know what rating of fuses were fitted where, but it seems that the wrong rating fuse had caused this. I believe that the fuses had already been in place when I got this wiring loom from another car. I did find out that the fuse ratings for the S3 fusebox were incorrect in the back of the 1100/1300 Haynes manual, so make sure that you use another source of information when checking the ratings for S3 cars.
Stuart
PostPosted: Fri Jan 09, 2009 8:41 pm    Post subject: Reply with quote
I had the same silly problem Colin!, When I bought my series three the seller told me the hazards and clock didn't work and I accepted the fact and went on my merry way...it wasn't until month later I checked the handbook and fuses and one was missing! the correct rated spare was even mounted in the middle of the damn thing! Embarassed
PostPosted: Mon Jan 12, 2009 5:48 pm    Post subject: Reply with quote
Glad it's not just me! What baffled me most was the lack of any problem with any component or wiring circuit and yet still no hazards... All working fine now.
