Is my differential knackered?
Post new topic   Reply to topic    Allegro Club International Forum Index -> Gearbox
PostPosted: Wed Jul 08, 2015 9:54 am    Post subject: Is my differential knackered? Reply with quote
Hi folks, had been trying to get my Allegro back on the road in March/April but hit a problem when I thought that the differential was knackered, so I left it for over 2 months Confused
I have removed the O/S inner CV/pot joint, finding the diff output shaft has play and can be wiggled about very visibly.
However, having measured the play as best I can, it is actually only between 1.3-1.6mm at the end of the shaft.
There doesn't really appear to be any in-out play (a little hard to be absolutely certain because trying to pull/push the shaft introduces movement in the left/right/up/down direction).
The N/S inner CV/pot joint has a small amount of play.
Having done a more thorough internet search than when I first found the problem, I came across this thread on a Mini forum, which suggests that actually all might be well:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=250065
So perhaps the 1.3-1.6mm of play is OK? Might need to check how exactly much play is in the N/S inner CV/pot joint, but it isn't much.
Can anybody confirm if all is OK with my diff or not please? Smile
Ta, Bolin
Post new topic   Reply to topic    Allegro Club International Forum Index -> Gearbox All times are GMT
