Engine oil
Post new topic   Reply to topic    Allegro Club International Forum Index -> Engine
Phil Bagley
PostPosted: Sat Apr 05, 2014 11:23 pm    Post subject: Engine oil Reply with quote
Can someone advise on the correct engine oil to use, for my 1300. I've heard that 10W30 semi synthetic is best (despite 10W40 having been specificed from new), but want to check that's right especially with the engine and gearbox using the same oil. Thanks.
Phil
Allegro 1.3 SDL 1979
PostPosted: Sun Apr 06, 2014 3:31 pm    Post subject: Reply with quote
http://www.opieoils.co.uk/pv-89910-millers-classic-mini-oil-20w50-millers-oils-classic-sport-mini-oil-1-litre.aspx?utm_source=ProductSearch&utm_medium=GoogleBase&utm_campaign=GoogleBase_ProductsFeed&utm_content=89910&gclid=CK26svqVzL0CFekBwwod71sANA
Is what you want. The grade you mention is too thin, Phil, though would work with advantage (10w40) on a remanufactured engine. Otherwise it's 20w50 grade for our old cars.
It's advisable to change the oil & filter every 3,000 miles or yearly (whichever comes first), and keep a tin handy for topping-up between changes.
Also avoid synthetic oil - stick to mineral oils.
Austin - you can DEPEND on it!
Squeak, rattle & roll
Phil Bagley
PostPosted: Tue Apr 22, 2014 7:28 pm    Post subject: Reply with quote
Many thanks. I got Millers classic mini oil, 20w50, the old oil was very black indeed even though it had done only 1500 miles but 2 years. The gear change feels smoother
Phil
Post new topic   Reply to topic    Allegro Club International Forum Index -> Engine All times are GMT
