Non-working indicators!
LankyTim
PostPosted: Sat May 03, 2008 12:52 pm    Post subject: Non-working indicators! Reply with quote
The indicators have packed up on my 1500 S2. Its been off the road for a few months. When it was on the road everything was fine but after a few weeks off the road the right hand indicators packed up then the left ones did a month or so later. Hazards still work ok. Any ideas on what the problem is? The same happened to two other allegros I owned a while ago.
Thanks!
View user's profile Send private message Send e-mail MSN Messenger
crippsacars
PostPosted: Mon May 05, 2008 7:54 am    Post subject: Reply with quote
I guess checking the fuses is obvious but you just try flicking the hazard switch on and off a few times - not quite sure why but this can often cure non-working indicators - give it a try!
Roger Feist
PostPosted: Mon May 05, 2008 9:22 am    Post subject: Reply with quote
Try changing or flicking the relay that sits under the dash just behind the steering cowl Smile
It's always better with the roof down ! It's the crayford's way !!
LankyTim
PostPosted: Mon May 05, 2008 1:41 pm    Post subject: Reply with quote
Just went outside to try the suggestions and they have appeared to have fixed themselves! Hope they remain operational long enough to get though the MOT.
Thanks guys!
LankyTim
PostPosted: Tue May 12, 2009 6:29 pm    Post subject: Reply with quote
Indicator problems again!
First of all the indicators stopped working again, then would only work one side, then the relay fell to bits. A quick trip to my hoard of bits found a good used relay (half as big as the original?). Now the "left" indicators work perfectly with a nice loud "click, clock" sound but the right indicators dont work at all. This isnt a problem when im returning from work as I only have to turn left, but when im going to work I cant let anyone know where im going.
Its only a matter of time before I dissapear under a lorry or something.
Help!
1979 Allegro 1500 S2 special 4 door saloon
Previous allegros,
1977 Allegro 1300 super 2 door. SCRAPPED
1978 Allegro 1300 super 2 door. SCRAPPED
PostPosted: Tue May 12, 2009 8:04 pm    Post subject: Reply with quote
Do they all flash with the hazard switch or not? If they all do then it might be the stalk that's got a problem.
Also, isn't the direction flasher unit smaller than that hazards flasher unit? If you've got direction relay in place of the proper hazards unit then the hazards might not work too well.
Hell has frozen over...... the car formally known as 'Heap' is back on the road!
LankyTim
PostPosted: Tue May 12, 2009 8:18 pm    Post subject: Reply with quote
The hazards do all work, but they flash very quickly.
The hazard relay is big but the indicator relay is small. Previously the indicator relay was big. Until it fell to bits and I replaced it. Possibly it had been fitted with the wrong type.
Previous allegros,
PostPosted: Wed May 13, 2009 4:51 pm    Post subject: Reply with quote
It sounds like you now have the correct relays fitted, and that the hazards are flashing quickly because the indicators are not working on one side, so it probably won't be the stalk switch at fault. Have you checked the connector onto the back of the hazards switch?
LankyTim
PostPosted: Wed May 13, 2009 6:23 pm    Post subject: Reply with quote
All sorted. I found that if the indicator stalk was pushed down in a certain way the left hand indicators worked. Looks like cack on the contacts in the indicator stalk or something.
With a bit of a wiggle about (of the stalk) the indicators seem to be working perfectly.
The hazards are still flashing quickly but all four indicators are working.
Thanks for the help Colin!
Previous allegros,
PostPosted: Thu May 14, 2009 7:13 pm    Post subject: Reply with quote
Characteristic of the model, sir!!!!!
