Ammeter
PostPosted: Thu Oct 04, 2012 1:26 pm    Post subject: Ammeter Reply with quote
I would like to fit an ammeter to my car. Can anybody tell me the way to do it with an alternator please?
Or would a voltmeter be more useful given the charging power of alternators?
Austin - you can DEPEND on it!
Squeak, rattle & roll
giz
Site Admin
PostPosted: Thu Oct 04, 2012 2:34 pm    Post subject: Reply with quote
go for a voltmeter, they are much safer and easier to use.
you just take one 1 wire to the +v of the battery and 1 to the -v side.
with an ammeter you have to slice through a cable so that the current flows through the meter, too much current = fire, poor connection = electrical gremlins.
plus voltage is easier to understand, 14.4v = good <12v = bad.
PostPosted: Thu Oct 04, 2012 5:12 pm    Post subject: Reply with quote
Yes I am concerned about the fire risks, but wouldn't the voltmeter in that case be more dangerous by running wires directly from the battery? Battery cables are very hefty after all.
PostPosted: Thu Oct 04, 2012 5:59 pm    Post subject: Reply with quote
You have it backwards; the ammeter has to be run direct from the battery - in fact, it has to be between the battery & everything else on the car, so is normally fitted into the live feed. This means a couple of hefty pieces of cable carrying the entire current load into the dash & back out. Voltmeters on the other hand can go anywhere & run off anything - I saw one on FleaBay this week that simply plugs in as a cigar lighter accessory!
...that's why Allegro will look as good 5 years from now as it does today.
giz
Site Admin
PostPosted: Fri Oct 05, 2012 6:47 am    Post subject: Reply with quote
volt meters are wired parallel to a circuit - no load, no fire, no problems.
amp meters are wired in series with a circuit - load etc etc
PostPosted: Sun Oct 07, 2012 3:43 pm    Post subject: Reply with quote
http://www.ebay.co.uk/itm/261056357412
PostPosted: Sun Oct 07, 2012 4:06 pm    Post subject: Reply with quote
Thanks Richard but must be the period Smiths' gauge to fit in with the car.
I have my eye on one...
PostPosted: Mon Oct 08, 2012 8:18 pm    Post subject: Reply with quote
You don't need all that current to pass through an ammeter if you use an inductive ammeter, you just need an inductive loop which passes across the rear of the clamp-on type ammeter.
Google inductive ammeter, have a look on ebay. There are two types of ammeter, the inductive (proximity) ammeter may come with installation instructions, if not, let me know & I'll tell you how Smile
PostPosted: Mon Oct 08, 2012 8:35 pm    Post subject: Reply with quote
I must admit that as a schoolboy I used to be fascinated by the ammeter in my Grandad's Vanden Plas Princess 1300 and the way the needle constantly fluctuated as electrical equipment was switched on and off (especially the indicators)
It was probably one of the last BL cars so equipped, as all Rovers and Triumphs from the 70s onwards tended to be equipped with voltmeters instead (much less entertainment value)
PostPosted: Mon Oct 08, 2012 11:09 pm    Post subject: Reply with quote
The ammeter I fitted to my first Allegro was quite entertaining as well. You should have seen the faces on the passengers when smoke started appearing out of the dash and how quickly they all got out and scarpered!!!
I did have a moment of panic but the short circuit was, fortunately, short lived and no real harm was done. Shocked
ruSSell
PostPosted: Tue Oct 09, 2012 5:10 am    Post subject: Reply with quote
Ive seen one of these in action and they are indeed fascinating to watch, would make any journey that bit more entertaining!
ruSSell
PostPosted: Tue Oct 09, 2012 5:11 am    Post subject: Reply with quote
That happened to the headlight switch in my Spitfire I used to have - dad certainly was lively that day in exiting the vehicle!!!
PostPosted: Thu Dec 27, 2012 6:32 pm    Post subject: Reply with quote
Fitted a Voltmeter in the end and a proper temp. gauge as my Christmas presents.
I will ask Giz to upload some photos in the 'General' section over the next few days.
The Voltmeter was indeed the right choice as an alternator is always going to whack out plenty of amps over a dynamo.
Thanks chaps for the advice. Smile
PostPosted: Wed Jan 30, 2013 12:52 am    Post subject: Reply with quote
'Proper temp gauge'? Any more info on this?
As far as I know the original temp gauge on all models works lineally, with 'normal' in the middle.
Not like some cars which have electronic 'rigged' gauges, which can be totally useless in some circumstances - e.g. Rover 75, where the needle will be exactly in the middle position from anywhere between 75 and 115 degrees centigrade! No warning of dangerously high temperatures which can cause damage!
Hell has frozen over...... the car formally known as 'Heap' is back on the road!
PostPosted: Wed Jan 30, 2013 3:34 pm    Post subject: Reply with quote
I had the photos ready and then the website went down... this reminds me.
The gauge replaces the useless original as it reads from 40 deg. C to 120 deg. C.
The car sits at just over 70 deg. C and the cooling fan kicks in at around 80.
