MoT help...
Post new topic   Reply to topic    Allegro Club International Forum Index -> Suspension
AlexB
PostPosted: Sat Apr 16, 2011 12:00 pm    Post subject: MoT help... Reply with quote
Hi gents,
Allegro failed the MoT today; 'Steering column shaft has excessive end float'.
Is this likely to just be a coupling required or something similar?
Other than that it needs a suspension strap, so I'm quite impressed really!
Thanks,
Alex.
'When you're travelling economy, go first class'
View user's profile Send private message Send e-mail Visit poster's website
PostPosted: Sat Apr 16, 2011 12:54 pm    Post subject: Reply with quote
It sounds like the pinch bolt between the upper column and lower column needs to be tightened. This kept coming loose on my sister's estate. You can tell if it's this or the pinch bolt between the lower column and rack by trying to pull/push the steering wheel in/out. If it is one of these bolts it's very easy to tighten, although for the lower one you will need to move the carpets/soundproofing and remove the shroud. For the upper one you may need to remove the parcel tray, not sure.
Hell has frozen over...... the car formally known as 'Heap' is back on the road!
nick23
PostPosted: Sat Apr 16, 2011 2:33 pm    Post subject: Reply with quote
If its the steering colume iv got 1 if u need 1
PostPosted: Sat Apr 23, 2011 12:24 am    Post subject: Reply with quote
There's a bush that fits in the top of the steering column. I've never replaced one, so I don't know what kind of job it is. But I suspect that it is worn and needs replacing.
Good luck,
Post new topic   Reply to topic    Allegro Club International Forum Index -> Suspension All times are GMT
