Radio Line Fuse Rating.
Andrew Mallett
PostPosted: Tue Apr 05, 2011 10:30 am    Post subject: Radio Line Fuse Rating. Reply with quote
My Equipe doesn't have a line fuse for the radio.(It must have been butchered sometime) I've fitted a line fuse holder I chopped off the loom from my doner car but I'm not sure what the fuse rating should be. Is it 1.5 amp? If so, I have some 2 amp fuses. Would they be ok? The fuse holder I've fitted holds a fuse the same size as the fuses in the block under the bonnet.
I can get 1.5 amp car radio fuses locally but they are smaller in size, about the same as a 13 amp plug. Should I have fitted a smaller line fuse holder to accomodate this or is the bigger line fuse holder I've fitted ok. I can't remember if the fuse holder should be the smaller or the bigger one. Does anyone know please.
Thanks in advance.
Bloke from Norfolk. Wink
PostPosted: Tue Apr 05, 2011 8:39 pm    Post subject: Reply with quote
2 amps won't stop the radio from cooking itself if it goes wrong, but will certainly protect the wiring from damage and that is the most important thing Smile
Andrew Mallett
PostPosted: Wed Apr 06, 2011 10:12 pm    Post subject: Reply with quote
I changed the line fuse holder today to one which will take a 1.5 amp fuse. I feel happier with that.
