Stop CV joint knocking?
Post new topic   Reply to topic    Allegro Club International Forum Index -> General
Stephen bramwell
PostPosted: Wed Apr 27, 2011 6:07 pm    Post subject: Stop CV joint knocking? Reply with quote
I have had CV joints replaced in past when knocking became more than
slight. However recently mentioned to an" old timer" expert in BL cars
that mine was knocking again after only 3k miles! He told me to check
the suspension trim height as if not correct it would need a pump up
which often cures the knock. Mine turned out to have lost about 3cm in
plus in height on front wheels, a rough guide is to check if x3 fat fingers
fit between tyre top level & wheel arch (differs on MK1).
Job done & knock gone!
PostPosted: Tue May 03, 2011 3:56 pm    Post subject: Reply with quote
Stephen,
Does your Allegro have an 'A' series (998, 1098, or 1275cc) or an 'E' series (1485 or 1748 cc) engine, and is it manual or automatic?
Many thanks,
ALLEGRO = Agile, Lively, Legendary, Economical, Genial, Reliable & Outstanding.
Post new topic   Reply to topic    Allegro Club International Forum Index -> General All times are GMT
