nick23
Posted: Tue Dec 14, 2010 5:53 pm Post subject: Wiper motor |
| Hi has any1 got a front wiper motor 4 a 1.3 2door allegro n how much 07807986388 |
Posted: Wed Dec 15, 2010 9:43 pm Post subject: |
Hi Nick,
You might be able to replace the wiper motor brushes, clean out the old motor gearbox grease & put in some fresh grease to make it good as new.
You can buy new motor brush kit from www.moss-europe.co.uk as the wiper motor is the same as an MGB unit (GXE 7708 £60ish). Brush kit part number RTC198A £15ish.
The grease recommended for use in the gearbox is Ragosine Listate, some say Castrol LM grease can be used, but I use an LM grease on forklift trucks which I know does solidify after about 6 months use. Shell Retinax 'A' is probably a better alternative grease.
Have a look here www.mgb-stuff.org.uk/wipermotor.htm for a guide to changing the brushes etc.
When you re-install the motor etc., leave the wiper arms OFF, then operate the wipers & switch off, they should then 'park', then refit the arms etc. & test/adjust again |
alan wilson
Joined: 09 Oct 2007 Posts: 347 Location: Usually next to allegro and mig..in Blackburn
Posted: Mon Jan 03, 2011 8:42 pm Post subject: |
Hi Nick
You can use a Mini wiper motor too, just change thegearing for the Allegro one to get the correct sweep angle
Cheers
Alan _________________ Well someone had to do it..... |
nick23
Posted: Tue Jan 04, 2011 12:34 am Post subject: |
| Cheers alan iv changed the motor and found out its the wheel box |
