Wiperblades
Post new topic   Reply to topic    Allegro Club International Forum Index -> Electrical
Andrew Smyth
PostPosted: Wed Jun 12, 2013 10:47 am    Post subject: Wiperblades Reply with quote
Most websites I have tried (e.g. http://www.ebay.co.uk/itm/261171867864?_trksid=p5197.c0.m619 ) suggest that the wiperblades on an S1 saloon should be 11".
I've measured, and mine are 14". What should I be replacing my current blades with & and any recommendations where I should get them from?
PostPosted: Wed Jun 12, 2013 3:10 pm    Post subject: Reply with quote
http://www.ebay.co.uk/itm/390423499815?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
or the Club do a nice Tex pair but they are more expensive.
Austin - you can DEPEND on it!
Squeak, rattle & roll
Andrew Smyth
PostPosted: Wed Jun 12, 2013 3:37 pm    Post subject: Reply with quote
Perfect, thanks!
PostPosted: Mon Aug 12, 2013 3:12 pm    Post subject: Reply with quote
Any recommendations for the best to fit to a Series 3 (black arms) in terms of:
a) wiping performance
and
b) durability?
Thanks, Colin.
PostPosted: Sat Aug 17, 2013 8:08 pm    Post subject: Reply with quote
Colin - surprisingly Halfords still stock the correct size Allegro wiper blades, in black. Before I got hold of some stainless blades, these worked a treat in all conditions and lasted for as long as I can remember.
PostPosted: Sun Aug 18, 2013 7:07 pm    Post subject: Reply with quote
I have recently fitted new 14'' wiper blades to my S3 VP & have noticed how it's a struggle to wipe/move on a fairly dry windscreen so I will swap them for 11'' blades soon.
I had similar problems on an S3 Allegro driving into gale force winds a few years ago until I fitted 11" blades.
Also, the LH blade fouls the screen rubber at its lower edge. I realise that the blade sweep is too much but shorter blades will stop it fouling the screen rubber
PostPosted: Mon Aug 19, 2013 4:31 pm    Post subject: Reply with quote
The Halfords were the smaller size blades, I should have said instead of the 'correct size'.
PostPosted: Mon Aug 19, 2013 7:40 pm    Post subject: Reply with quote
I think the problems caused by using 14" wiper blades on our Allegros stems from the fact that the wiper motor & mechanism was originally designed for use in the Mini that had 10" blades originally (latterly 11" blades) & the MGB that had 11" blades & no doubt, shorter wiper arms.
PostPosted: Mon Aug 19, 2013 7:45 pm    Post subject: Reply with quote
Is that so? If I could get stainless 11" blades for the Allegro I would undoubtedly use them... and yet I have never given it any thought... stainless steel finish blades for the cars you mention Laurence are readily available. It would just be a case of finding ones which fit the arm.
PostPosted: Tue Aug 20, 2013 5:10 am    Post subject: Reply with quote
TEX Automotive 7.2mm bayonet/notched blade B14311 is stainless 11" blade, there is also hand polished option.
Make enquiry though, just to make sure the blade above is what you want.
PostPosted: Tue Aug 20, 2013 5:07 pm    Post subject: Reply with quote
Thanks Laurence. Smile
PostPosted: Sat Aug 24, 2013 8:20 am    Post subject: Reply with quote
Hmm I'm not sure about Halfords wiper blades - I fitted a rear one in 2009/10ish and it'd completely had it by last year, rubber split most the way along.
Considering the usage a rear one gets in comparison to the fronts (which are older and the rubber hasn't actually split but is turned over at the ends and the flexible metal has distorted so the blade doesn't touch all the screen when wiping) I don't think it has lasted at all well.
Was this a reasonable amount of time to last?
Or was it just a bad batch?
PostPosted: Sat Aug 24, 2013 2:01 pm    Post subject: Reply with quote
Perhaps it was a bad batch. But 3 years' service isn't bad, considering it is recommended to replace them each year.
PostPosted: Sun Aug 25, 2013 5:25 pm    Post subject: Reply with quote
I agree that the wiper blades should be changed quite often, maybe once or twice a year.
The blades split through lack of use sometimes, they quite often unknowingly stick to the screen due to dirt, ice, tree-sap etc. when the car is parked unused outdoors, then when the wipers are used for the first time for a while the blade being stuck to the screen breaks/splits.
Post new topic   Reply to topic    Allegro Club International Forum Index -> Electrical All times are GMT
