Dave Coates
Joined: 01 Mar 2010 Posts: 73 Location: Middlesbrough
Posted: Tue Jul 27, 2010 2:38 pm Post subject: fuel gauge |
just bought this off ebay...its for an MG, but looks very similar to an allegro sender. I`m going to to play to see if it will go in without any mods. Failing that, everythings at the right angle, just all looks about 10% bigger....if it don`t fit I`ll make it. It was only 12.50 plus a couple of quid p&p.. Might be a source for us lot eh? I`ll report back....
 _________________ A good bolt is better than a bad weld.... |
Dave Coates
Posted: Wed Aug 04, 2010 6:29 pm Post subject: |
went in no probs. Where the filter plugs on the end you need to cut inch and ahalf off and plug filter back on. Then just bend the fload bar to match the lowest point on the filter..... _________________ A good bolt is better than a bad weld.... |
Posted: Wed Aug 04, 2010 9:25 pm Post subject: |
Cool!
From an MG what?
What's the part number etc? |
Dave Coates
Posted: Thu Aug 05, 2010 5:03 am Post subject: |
Its from a mgb 75-81. I used my digital ohm meter to take a reading on the float with it out of the tank, so it was at the bottom of its travel, then had a few goes at bending the float rod so when it was in the tank at the bottom of its travel the reading was the same. You have to put a kind of loose "s" in it....Not sure what the reading if out or not as still have no fuel in it, but its all smiths, so can`t see it being out much _________________ A good bolt is better than a bad weld.... |
Posted: Thu Aug 05, 2010 3:52 pm Post subject: |
From the pics, it looks like the MGB pick-up tube is a bit longer, would this cause the suction strainer to foul the inside of the fuel tank?
Because it's a MGB unit, I think it will be compatible with the Allegro, so should work no probs.
Let us know how you get on. |
Dave Coates
Posted: Thu Aug 05, 2010 8:46 pm Post subject: |
Yeah, it is a bit longer. But I pulled the strainer of and cut off an inch and a half off the tube and pushed the strainer back on. It still sits within the delv at the bottom of the tank.. _________________ A good bolt is better than a bad weld.... |
