Dave Coates
Joined: 01 Mar 2010 Posts: 73 Location: Middlesbrough
Posted: Sat Apr 17, 2010 6:54 am Post subject: fuel gauge woes |
After painting the NOS fuel tank, I took the float out to check it as the guage never went north of "E". I put a multimeter across it and it showed open curcuit. I opened the (variable resistor/potentiometer??) up and it became obvious that the wound wire wasnt..........It looks similar to every other little-metal-box-on-a-petrol-float from cars of that ilk.....Has any one ever adapted sender units from other cars? If not complete units then how about just the resistor part? _________________ A good bolt is better than a bad weld.... |
Posted: Sun Apr 18, 2010 7:20 pm Post subject: |
Perhaps the new paint on the tank is (now that it has been painted) preventing the body of the tank from making a good earth connection to the body of the Allegro.
Also the new paint on/around the sender locking-ring could be preventing the sender from making a good earth connection to the tank body.
When the sender is fitted to the tank, & then the locking-ring is fitted, both the sender & the tank in the locking-ring area should make a good electrical connection (earth) otherwise the gauge will never work even with a new sender unit.
Clear the paint from areas around the tank securing bolts & the sender locking-ring & once it's all in place & tested/working, then paint these areas if required.
Earlpart www.earlpart.co.uk 01773 719504 or The Electrical Parts Company Ltd 01584 811118 may be able to supply a new sender. |
Dave Coates
Posted: Sun Apr 18, 2010 7:55 pm Post subject: |
no, sorry, what i meant was, The old tank leaked at the seam. So as i had to remove the tank to do the welding under neath and to fit the new tank anyway, I checked the float on the bench, connecting the ohm meter straight to it. When it registered open curcuit, thats when I opened it up and found the corrosion...... _________________ A good bolt is better than a bad weld.... |
Joined: 21 Jan 2007 Posts: 804 Location: Farnham, Surrey.
Posted: Tue May 18, 2010 4:18 pm Post subject: |
Dave,
The sender part number is, I believe, ADU3220.
If Colin Taylor, our spares genius, cannot help, if you do a Google search with this part number. It does come up with more than one supplier, but the first one I tried says it is £65!
I don't believe you will buy the resistor separately, and if you 'rewind' it you would need wire with the correct resistance value.
I hope this helps.
Merv. _________________ ALLEGRO = Agile, Lively, Legendary, Economical, Genial, Reliable & Outstanding. |
Mike Dean
Joined: 01 May 2007 Posts: 455 Location: North London
Dave Coates
