seats 2/4 doors
Post new topic   Reply to topic    Allegro Club International Forum Index -> Bodywork & Interior
norway_triumph
PostPosted: Mon May 03, 2010 7:20 pm    Post subject: seats 2/4 doors Reply with quote
are the seats from 2 doors the same as 4 doors so that it would only be a matter of changing the "frames" to get access to the rear seat in a 2d. ?? Or are they so different that it's better to source a couple of good 2 D - seats ??
Jan-Ivar
Driving is believing
http://www.albion.no.com./
http://www.morrismarina.org.uk/
PostPosted: Tue May 04, 2010 5:38 am    Post subject: Reply with quote
2-door seats have latch handles on the side to slide/tilt them for rear access. Depending on age/trim level, 4-door seats may or may not have reclining mechanisms but they're not sufficiently foldable to allow access to the rear seats. I believe the frames are not interchangable, nor would simply swapping the base frame allow you to change 4-door seats into 2-door seats because of the side handles - you'd basically have to rebuild the whole seat.
PostPosted: Tue May 04, 2010 5:25 pm    Post subject: Reply with quote
The frames are different, as are the cushion covers. The squab covers are identical however, except for the hole for the tilt/slide latch handle.
norway_triumph
PostPosted: Wed May 05, 2010 4:18 pm    Post subject: Reply with quote
thanks - guess i'll keep looking for 2d seats then Smile
Jan-Ivar
Post new topic   Reply to topic    Allegro Club International Forum Index -> Bodywork & Interior All times are GMT
