Series 3 Dashbord
Post new topic   Reply to topic    Allegro Club International Forum Index -> Wanted
Peter Greenwood
PostPosted: Thu Jun 18, 2015 9:55 pm    Post subject: Series 3 Dashbord Reply with quote
Does anyone have a series 3 dashboard assembly to replace the one on my 1.3L?
Grateful for any help in finding one. Sad
Peter Greenwood
PostPosted: Sat Jun 20, 2015 8:55 pm    Post subject: Re: Series 3 Dashbord/Instrument Cluster Reply with quote
In case I didn't make myself clear: I need an instrument cluster for my series 3 1.3L
Dave Smart
PostPosted: Sun Jun 21, 2015 5:17 pm    Post subject: Reply with quote
Theres one on the bay at the moment item 251985654409 series 3 £35 pius £7.95 postage make them an offer
The Super Vroom Bitch Is Back...............
Peter Greenwood
PostPosted: Mon Jun 22, 2015 9:01 am    Post subject: Reply with quote
Thanks Dave. Yes I have seen that one, but it looks nothing like mine, it must be from a higher spec variant. looking at the one on eBay I get the impression that it is wider than the one on my 1.3L and therefore will not fit into the binnacle on my car. However I have to admit that I don't know if this is just an illusion? Does anyone know if the higher spec series 3 cars had larger instrument clusters? If I can be sure that they are all the same size I would be willing to take the risk that the one on eBay may work on my car.
Peter S
PostPosted: Mon Jun 22, 2015 7:17 pm    Post subject: Reply with quote
Peter
I'm guessing that your car is a series 3 facelift, where the 'L' designation means bottom of the range. In which case it has only two instruments, one being the speedo and the other split between fuel and temperature. The higher spec version with clock (as per the ebay example) or even rev-counter are exactly the same size and are a direct replacement so you would have no problem fittiing it instead
Peter
Peter Greenwood
PostPosted: Mon Jun 22, 2015 8:31 pm    Post subject: Reply with quote
Peter S wrote:
Peter
Peter
Peter.
Yes it is as you describe.
Many thanks for your most helpful info.
Peter. Cool
Peter S
PostPosted: Fri Jun 26, 2015 9:55 pm    Post subject: Reply with quote
It dawned on me yesterday that I have a spare series 3 base model instrument cluster should you still be looking. Was all working when removed from car 4 years ago. Let me know if you're interested.
Post new topic   Reply to topic    Allegro Club International Forum Index -> Wanted All times are GMT
