Posted: Tue Jul 24, 2012 11:22 am Post subject: Solenoid part numbers |
I've been playing with the Parts List CD to try & identify my starter solenoid, which is the next part for me to check in the quest to get Tara to BL Day.
I think the part number is 13H5952, but I can't see how to translate that to equivalent Lucas parts (which is the numbering that seems to be preferred by eBay listers); am I just being stupid, or is that not covered? _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
Posted: Tue Jul 24, 2012 1:33 pm Post subject: |
That's the thing; there's 3 & 4 contact versions, both advertised as suitable for Allegros. That one doesn't state which it is, and I'm not 100% which I need as I've not been back to my car yet - ah the perils of having a remote lockup! _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
Posted: Tue Jul 24, 2012 2:12 pm Post subject: |
What we could do with is some sort of parts number cross-reference guide i.e. BL part no. X = Lucas part no. Y.
I t think there difference is between series 1/2 and series 3. Not sure which is which though. _________________ Hell has frozen over...... the car formally known as 'Heap' is back on the road! |
Posted: Tue Jul 24, 2012 10:48 pm Post subject: |
I did find 2 parts listed in the parts list but it said that the second superseded the first due to it being no longer available. _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
Posted: Fri Aug 03, 2012 1:12 pm Post subject: |
Right; Tara has a 4-terminal solenoid, which (to be more confusing) has 6 terminals. However, some Allegros have the 3-terminal ones, and I have kindly been offered the purchase of a 3-terminal one at BL day should nothing else be sourced before or at the event.
As far as I can tell, the 4 terminal ones simply have 2 siamesed terminals for different wires where the 3-terminal one has a single terminal. If those wires were connected in another manner, would the 3 terminal solenoids be usable in my car? _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
giz Site Admin
Posted: Sat Aug 04, 2012 12:04 am Post subject: |
providing that what you say about just having siamesed terminals is correct then yes.
early and later minis had 2 types 3 and 4 terminals also, the only difference is, as you've described (that and the price). |
Joined: 21 Jan 2007 Posts: 804 Location: Farnham, Surrey.
Posted: Sat Aug 04, 2012 6:45 am Post subject: |
The 4S inertia starter solenoid shown will have:
Two large connection points (From the battery and to the starter motor. The battery live terminal usually has additional feeds taken from it)
One 'lucar' blade connector from 'line 50', starter solenoid feed from the ignition switch. Wire colour typically white with a red tracer.
In addition some will have an additional 'lucar' blade connector which becomes 'live' when the solenoid is operated. This is used to feed the ignition coil, bypassing the ballast wire on a 'cold start' coil system. Such a system enhanced the maximum coil output kV for improved cold starting. Such a system was employed on some Allegros - usually S3.
Thus a 'four terminal' solenoid can be used with or without any connection to the fourth terminal.
Merv. _________________ ALLEGRO = Agile, Lively, Legendary, Economical, Genial, Reliable & Outstanding. |
Posted: Sat Aug 04, 2012 10:47 am Post subject: |
Ah so it'll only affect my cold start facility? Well that's fine!  _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
Posted: Sat Aug 04, 2012 2:06 pm Post subject: |
Richard,
A little more info.
If your car has a cold start coil fitted the additional wire going to the solenoid will be white with a yellow trace. At the coil + terminal there will be at least two wires, the same white/yellow and normally a pink/white from the ballast (resistance) wire.
The wrong coils are often fitted. (My recent purchase was fitted with an incorrect coil for the ballast system on the car!) If it is a ballast system the coil primary resistance shoud be around 1.5 ohms. If it is an 'ordinary' system the coil primary resistance should be around 3.5 ohms.
PS Lets hope for good weather tomorrow! _________________ ALLEGRO = Agile, Lively, Legendary, Economical, Genial, Reliable & Outstanding. |
Posted: Sat Aug 04, 2012 2:30 pm Post subject: |
Thanks for the extra info Merv. I've successfully had her up & running, thanks to Andy & Colin's "bypass" suggestion, and now we just have to hope I can find a suitable replacement  _________________ ...that's why Allegro will look as good 5 years from now as it does today. |
